Ana içeriğe geç
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
151 Soru Tümünü görüntüle
Will an Xbox One X still function with a removed disk drive?
As the subject indicates, if I do not use any optical based games, will the Xbox still run with one not installed? Or will the PCB from the drive still at least need be connected? I ask because I will be installing my second Xbox into a custom case. Which I understand is warranty voiding, but it was bought used.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes it will work fine but keep in mind that at some point they might start doing what Sony is now doing…requiring a hardware check with each update. If the disc drive isn’t working on a PS4 then it won’t update.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
you can attach the daughter board from the drive as a workaround that!
tarafından
Is this still the case now or did they do what Sony did?
tarafından
Yorum Ekle
Yanıtını ekle
Marlon Lee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 1,657
