Credit goes to Jessa at iPad Rehab, made a summary below of video:
PP3V0_ACC (From U2 Tristar chip [ACC_PWR], Pad D5 is location of it under chip) is used for powering lightning accessories (usb fan / HDMI adaptor / unusual stuff) from the lightning dock connector.
Phone will still charge normally without PP3V0_ACC with iPad / iPhone wall chargers and USB connection to computer still works.
Source for PP3V0_ACC explained:
https://www.youtube.com/watch?v=OsIKeFnd...
Below is potential solution from a GSMhosting thread
For PP1V1_GPU short it could be caused by U7 (Power Management chip)
Removing l13 and l14 I assume can be used to confirm if U7 is causing short.
Source for PP1V1_GPU short solution at Post #2 of thread post:
http://forum.gsmhosting.com/vbb/f631/iph...
Edit forgot to say with PP3V0_ACC missing the phone will charge half speed if a USB ammeter is used. 0.9ish-1.0 Amp is expected charging speed for normal charging.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum
Hi Ben,
Thanks for a quick response. I found out already that PP3V0_ACC does not impact charging but does it affect boot or when trying to restore? Since PP3V0_ACC and PP1V1_GPU are created by PMIC I probably should suspect it first?
Karolis tarafından
