Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
Phone won't turn on
I got a phone from a friend who needed help replacing the screen after dropping it and breaking it.
First thing before even buying a new screen I wanted to see if the phone is still working so I plugged it in my computer, itunes installed, but my computer can't see it at all.
(No device recognition sound or anything on the computer screen, itunes can't see it)
How can I fix it?
Bu iyi bir soru mu?
Puan 0
3 Yorum
The phone seems to be charging fine though, I can feel the heat when it is plugged in. normal heat.
tarafından
How long have you left it charging for?
It could be that the battery is flat for the time being and needs more time for it to charge up enough to turn on.
3Utools application from 3u.com may help you with detecting whether the iPhone has booted properly with the cracked screen.
It does sound like the LCD display on the screen has also gone bad not just glass resulting in no image on the screen.
tarafından
That was it, After charging it for about half hour it showed sign of life. I thought apple mobile device can power on without a battery. (as long a cable is plugged)
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
After charging it for about half hour it showed sign of life. Weird I thought it could power on without a battery.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Press and hold the two buttons at the same time
Puan 0
1 Yorum:
That's the first thing that I've tried. (Home and Power)
tarafından
Yorum Ekle
Yanıtını ekle
Roje Ha sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 116
