Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
PS4 doesn't start blinks blue
Hey everyone,
I have a PS4 which won't start. All that happens is that the blue light turns on and continuously dims and brightens again. No white light appears, and the PS4 doesn't respond to the controller. I've already tried using a different power supply, but no luck there. I'd greatly appreciate any help.
Thanks in advance,
Minas
This is a different PS4 to the one mentioned in my other thread.
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
After quite some time searching I’ve come to the conclusion that it is probably a problem with the APU chip. The next step now will be to take a look at reflowing the motherboard, but I highly doubt it will work permenantly.
Anyway, thanks for all the help!
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
What???? How do you do that mine won't power on at all it had the issue of having to reset it by unplugging and replacing the cable and it would work but this time all that happens is the blue light flashes then it becomes unresponsive. No light what so ever. I took the plastic off amd cleaned all the dust but didn't do and good think it could be the power supply?
tarafından
Yorum Ekle
En Yararlı Yanıt
there are a few things it could be the the apu chip, ram or southbridge chip. but theres no way to test which 1 it is
Puan 1
Yorum Ekle
go on Xbox should fix the issue.
Puan 1
Yorum Ekle
here's a link i found that may help further diagnose it. I hope it helps.
https://www.usgamer.net
Puan 0
4 Yorum:
Since I've tried with different TV's, Power Supplies and Hard drives, I can guess it's only an internal issue. :/
tarafından
I will check and see if I can find a solution other than contacting Sony.
tarafından
Any luck yet?
tarafından
I apologize, I think you are correct in your determination of the APU chip. It requires microsoldering and could be difficult to repair. I wouldn't use the heat gun method as this is likely to do more damage than fix the issue.
I would check with Louis Rossman to see if they are able to change this for you.
https://www.rossmanngroup.com/
tarafından
Yorum Ekle
Hi
I had this problem too, it took ages but eventually I found an easy fix!
Follow the linked guide and never have problems with your console again
Your welcome in advance
https://bit.ly/2xJ2kC8
Puan 0
1 Yorum:
I tried this repair and couldn't get my PS4 repaired. Though I did fix my gaming problem.
tarafından
Yorum Ekle
Yanıtını ekle
Minas Mayth sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 25,518
