So, as I said before it could be a lot of things and it looks like it might be complicated.
- First, you need to disassembly your laptop, you could do it by following this guide for battery replacement: guide.
- Check if the motherboard if contaminated by dirt and if so clean it up, if the problem persist...
- Try powering up your laptop with the battery disconnected, in order of determine if your battery is in bad shape.
- If the problem continues, you´ll need to test with a multi-meter if you have voltage in the board, and what happens with that voltage when you press the power button. It could be a component in the main-board that is creating a short once it gets voltage.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
Could be happening lots of things, but first I need to know:
-Was the laptop working properly and then shutdowns while working?? or you shut it down correctly and later it wont power up????
-The battery was working fine??
-Has you try another power cord??
Luis Anniel tarafından
yeah it was working perfectly fine . I just shut it down for bed then tried using it the next after noon and nothing. The battery was accepting charge and functioning correctly and I recently got a new power cable today, that's what prompted me to write this
Charlie tarafından
same issue here, could you solve it?
Hendrik Holst tarafından
no. I just eventually gave up. I think its just a dead motherboard.
Charlie tarafından
