Do I need to replace my screen to remove the screen lines?
My 1-year-old brought my phone for a dip in a bucket of water while it was in an Otterbox case. I took the phone from the case ASAP and turned it off, then put it in rice (before I read that it is not recommended). Turned it back on after an hour or so and saw screen lines, but the touch screen was responsive and there didn't seem to be any other problems.
I followed the directions for water damage to a degree: opened up my phone, disconnected the battery and saw that there was some water that had entered the phone and wiped it up with toilet paper, then wiped away the fibers with a clean paintbrush. Turned it back on, still lines. Opened it again, but this time i disconnected the screen from the phone and let it dry out overnight. Reassembled it and lines are still there, but not quite as bad. I'm wondering if I should just deal with it, since there don't appear to be other issues and I can still see the screen and what not, even though it looks a bit like a game boy screen now, or if I should replace the screen. Thoughts? Thanks!
Bu iyi bir soru mu?
4 Yorum
Also, I did not replace my battery, despite that recommendation, since there didn't seem to be any issues, but I guess that is something I might need to do, as well.
Alex Kosmider tarafından
[image|1512618][image|1512617]
These are photos of the screen, (assuming they upload correctly) and it doesn’t show much. It just generally looks more like a Game Boy screen now.
You are very accurate with the Gameboy-Like Screen. More-or-less its water damage. Replacing the LCD should correct it. Just remember, take your time and follow the guides. Although its easy, it's also easy to mess up. Especially with the fragile cables.
Juax tarafından
Update: my screen was starting to look progressively worse, but this morning I noticed that the screen looks perfectly normal now—no lines at all! So I am glad that I waited before calling it quits. Knock on wood..,
