Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Loud speaker sounds crackly/distorted after screen replacement.
I replaced an iPhone 6s plus screen for a friend and the loud speakers sounds distorted.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First thing to do would be to make sure the charging port is seated properly at the connector, as this could have been nudged when disconnecting the battery also check that the speaker itself is sitting properly above the contact points on the charge port flex. After that, the next step would be to try with a known working loudspeaker. This seems like a strange problem to have after a screen replacement, since the loud speaker doesn’t really get touched during that repair. Thankfully if the speaker somehow got fried, that part is usually under $5
Oh, make absolutely sure that there aren’t any screws floating around in the phone.
Come to think of it, I did see this happen once when a phone got closed with a screw stuck to the speaker magnet.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
yeah the screw trapped inside was my first thought but there's nothing stuck inside and everything seated properly, i guess it might just need a new speaker
tarafından
Happens to the best of us. Thankfully it's a cheap part to replace and an easy one to source.
tarafından
Yorum Ekle
Yanıtını ekle
Tom Read sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,517
