I've broken the DSI motherboard power connector!
I recently bought a "for parts" DSI off of Ebay. The lower screen was broken, but I'd replaced a DS lower screen and figured I could handle it. I used the instructions on this website to begin the disassembly of the unit, when I got to the point where you disconnect the power cable from the mobo (step 9) I ran into a problem: the entire connector, not just the cable, came off the mobo. Is there any way to reconnect the mount point for the power connector or is this a matter of suck it up and send it out to a repair tech? I'm going to look at under a magnifying glass and hope I can solder it back on, but I'm not certain that will work. Any suggestions most appreciated.
Bu iyi bir soru mu?
5 Yorum
As a side note, I've noticed what appears to be either water residue or some type of glue on various parts of the motherboard. also, before the teardown, the unit did power on when plugged into a wall charger. It appeared to just be a broken LCD was the issue with this unit. (but I could be wrong)
AdamMcinturff tarafından
AdamMcinturff, is there any chance you can post a pic of the damage. I think that there might be a way, if you are pretty handy. Of course you can also send it off to get it repaired, however make sure that you get a good cost estimate in order to not spend more than a replacement DSi would cost.
oldturkey03 tarafından
Just to update, it is quasi-repaired. I used alcohol to clean the motherboard and used; a flashlight, a soldering pencil, and a magnifying glass (at this point there was someone else helping, let's face it my soldering skills are only so-so) and we ever so gently soldered some extra wire directly onto the mobo and then soldered that to the connectors from the power supply board. sadly the case wont close completely (to much wire I suppose) and occasionally the thing acts as if the up or down button is constant on. any idea where I can find thinner wire?
Check a electrical supply house for thin wire. Good luck. + for your effort.
rj713 tarafından
+ I second that
