Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
144 Soru Tümünü görüntüle
Where is the fuse location on the board for mac pro A1706 backlight?
my a1706 mac book pro has no backlight, i can see apple logo on the screen with flash light. trying to check the back light fuse before i go to apple store for expensive repair.
But i don’t know where that fuse is located on the board. If anyone has that layout please help me
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Essential Electronics Toolkit
Small Toolkit. Big Possibilities.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@mdesai7482 the backlight fuse is a 3A 32V in a 0603 package
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
@oldturkey03 Thanks but no luck fuse is ok. still have same issue.
tarafından
@mdesai7482 if you have experience with board level repair you could trace your backlight circuit. If yo do not I suggest you contact those active users on here that do have the expertise and tools to do this for you. @tcrs_circuit in the USA @reecee in the UK and possibly even @refectio in Canada @arbaman in Sardinia (Italy) ;-) @rany in Lebanon and many others
tarafından
Thanks
Do you know where is the connector for the backlight?
tarafından
@mdesai7482 I do not quite follow you with that. What kind of connector? What is on your mind....?
tarafından
Sorry, I mean any connector that relates with backlight, through which it gets signals from motherboard.
i don't have diagram so trying to trace the circuit of backlight.
or clean that connector see what happens. otherwise apple gave me estimate of $450 to fix it.
tarafından
5 daha fazla yorum göster
Yorum Ekle
Backlight failure other than the screen on these is rare. Fuse failures are almost non existent unless you plug the screen in with power. It is probably a LCD issue. Of course if you have obvious corrosion on the board, address that before blaming the LCD. I’d put my money on the LCD though.
Puan 0
Yorum Ekle
Yanıtını ekle
manish sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 93
Her zaman: 1,167
