My tail lights will not turn on
I have a 2005 Toyota prius and my tail lights will not turn on but my breaks head lights and flashers work just checked fuse it was fine and changed the bulbs what can it be????
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Casey Knight, check the T-LP relay. The T-LP relay Turns taillight and illumination on when it is actuated by taillight ONdemand signal via main body ECU. If that is okay and your bulbs and fuses are okay yo umay encounter an issue with the ECU. Here is the Lighting chapter Lighting.pdf to help you further troubleshoot your tail light issue. Let us know what you find
Bu yanıt yardımcı oldu mu?
Hey oldturkey, I have the same issue. thanks for the tips on the tl-p relay. What are the visual signs of a bad relay? Or is it best to buy a new relay and replace it and see if that solves the issue? thanks!
@maxbailey a relay is just a switch. Always check the base of the relay and see if you have power coming to it when you activate the lights. If it got power to the base then it is most commonly the relay. Luckily these are pretty common and not very expensive ;-)
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 2,174
