Ana içeriğe geç
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Soru Tümünü görüntüle
My early 2009 17" mbp won't start after it has cooled down
This started last winter
The same happens if the computer is asleep, I will come back to it, it a key to wake it up, the screen turns on a split second and it turns off, then pressing the power button does nothing
I have now replaced the battery, but still have the same problem
The only way to turn it back on is to physically heat it slowly for about 10 minutes (on a wall heater, or on an electric stove, so the top case feels warm to the touch, then do an SMC reset (holding shift-control-opt and the power button 10 sec) then pressing the power button again. Sometimes it boots up half way and shuts down, but pressing the power button again (and or another smc reset I forgot) and it will complete the boot, and be fine
Have you guys seen this elsewhere?
Thanks
Update (08/30/2018)
Ok thanks for your help, I should add that I replaced the battery because the original was swollen up big,and not leaking if it helps
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sounds like one or more of the caps are breaking down. You’ll likely need to have someone with good micro-soldering skills and access to the needed parts take a look at it. It might be not too costly.
The other direction is to just replace the logic board while not cheap it will be the easiest direction. Here’s the IFIXIT guide MacBook Pro 17" Unibody Logic Board Replacement and here’s the available board MacBook Pro 17" Unibody (Early 2009) 2.66 GHz Logic Board.
I have a 2011 17” model which I just love! The bigger display makes picture editing so much easier so don’t be to quick to throw it away!
MacBook Pro 17" Unibody (Early 2009) 2.66 GHz Logic Board Görseli
Ürün
$159.99
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I agree, had a few repaired with this issue, it might be one of the small tantalum capacitors that has worn out.
tarafından
Yorum Ekle
Yanıtını ekle
Stephan Moitessier sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 54
