97 Toyota Camry randomly will not crank
97 Camry randomly won’t start. New battery, starter w/ solenoid, alternator. Every now and then car won’t start- leave it alone for a while and then it starts??? any ideas?
Bu iyi bir soru mu?
Puan
How many miles? Any codes/Check engine light?
Stacey tarafından
100k, check engine light for EGR valve, code for same but nothing else
Crystal Coleman tarafından
I don't believe the EGR itself would prevent your car from turning over. Even if extremely clogged i think you would be experiencing more of a stalling issue instead of "no crank". When you put the key in the on position do you hear a light buzz,hum?(im terrible at describing sounds) letting you know that the fuel pump is working properly
Stacey tarafından
