One game works fine others work okay and some don’t work at all...
Okay so I have a super slim 4001b model. It was dropped recently with in a bag which gave it some cushion, but unfortunately has lead to a problem. I’m curious to what had broke so I can replace, if possible.
My guess is that I need a new disk reader but would rather get a better hypothesis or answer before I go out and waste money.
Now I’ll be brief and tell you what I can tell you.
When start up it sounds like it tries to spin the disk but can’t and takes 3/4 attempts then finally continuously spins, sometimes with a little tap or two.
when loading game tends to make a weird noise, more so in games I already know it’s most likely not going to load
It plays all apps fine Netflix, YouTube, Hulu, etc.
the only game that work perfectly fine with with the exception of two weird lines that pop up for a sec seldomly, which I do not recall happening before, is Battlefield 4
MW3 survival game mode worked perfectly fine too but now experience very bad lag and time
BO3 works, sometimes with bad lag in zombies
BO1 does not when loading the game volume cuts in and out and freezes most of the time resulting in me having to $@$* of the console due to freezing completely and could take up to 10 try’s before it actually can load all the was through. Noticed that if I hold down the ps button on the controller and go to the quit game, controller assignment, etc menu that has a better chance of loading up with out freezing completely.
GTAV right after the drop incident, when trying to start would go to a black screen and couldn’t get out of it and the console would make a really bad noise like it was dumb or something. This weird noise happens with loading other games too. It usually tends to make the console vibrate.
Now after probably 5 months after the drop GTA now loads but after having to press X to pass the notice of a feature no longer available, to continue loading it freeze resulting in have to $@$* it off.
that’s really all I can tell you , and I hope at someone can help! Thank you!
Bu iyi bir soru mu?
