Ana içeriğe geç
The Expression Photo XP-960 wireless, wide-format Small-in-One printer puts professional-quality photo printing at your fingertips.
23 Soru Tümünü görüntüle
printer blue light flashing but not working
printer blue light flashing it dose the startup sequence but nothing els and the touch screen is off
Bu iyi bir soru mu?
Puan 2
3 Yorum
solved my problem
regards Stu
tarafından
Thank you very much; it worked.
tarafından
Fantastic. Many thanks as this worked for me.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello,
I have an Epson XP-800. When I power up, the power button lights up but the screen never comes on.
The power light blinks once every 10 seconds or so, but I cannot see what the problem is.
Help!
Thanks
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
hi turn on printer then unplug the power source then click each printer release button but don’t take them out.
this may be hard if the cover is over them but still possible.
plug back in and wait it should tell you that the cartridges are not installed
then click all back in good luck
regards rik
Puan 9
11 Yorum:
That worked! Thank you
tarafından
Thank you so much, this worked for me today the 04/04/2020.
tarafından
My XP 960 had the same problem and this fixed it. Thank you loads.
tarafından
thank you. Worked for me too
tarafından
Brilliant - worked like a charm. Thank you.
tarafından
6 tane daha yorum göster
Yorum Ekle
I have this exact issue, did you resolve it?
Puan 2
1 Yorum:
Fantastic just saved my bacon printing my daughters wedding invites it worked as you said
tarafından
Yorum Ekle
ok try this, take the power lead out of the back of the printer or turn off from the mains.
then open the lid and release each of the ink cartridges, you may have to use something fine like a small screwdriver as it will be in the docked position, you don't have to take the cartridges out.
plug back in and power up at this point it should come back on, good luck
Puan 1
Yorum Ekle
My printer is so 760 and I have the same fault
Puan 0
1 Yorum:
It works also with the XP-760 . Try it!
tarafından
Yorum Ekle
Yanıtını ekle
richard lawrence sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 5,717
