Ana içeriğe geç
Released in 2007. Identified by the model number FE-210 on the front of the camera.
4 Soru Tümünü görüntüle
How to replace battery cover
Olympus FE210 with a broken battery cover. how to replace it with a new one. it is help in place by a pin much like a watch band. do you have to take the whole camera apart- remove all 7 screws to replace the door?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You won't need to take the entire camera apart in order to replace the door. You will, unfortunately, need to remove the front casing of the device which will require you to unscrew those 7 screws. The guide on how to do so is here:
Removing Olympus FE-210 Rear Casing
It's pretty simple and shouldn't take too long.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Donna sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,986
