Ana içeriğe geç
Unveiled at the 1290 New York International Auto Show in 2004, the Xterra was redesigned for 2005 on the Nissan F-Alpha platform used by the Frontier, entering showrooms April 2004 for the 2005 model year.
6 Soru Tümünü görüntüle
Why is my driver’s side window not going up when the controll is pre
Power window does not respond when control pressed on driver’s window. It is stuck in the down position. All other windows work ok. Lock button is in the off position .
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey, Robert. This could be one of 2 issues. Either the switch itself or the window motor. You’ll need to remove the switch and use a multimeter to test the switch. If the switch is not your problem it is probably the motor. Here’s a video of someone taking their passenger door panel off of a ‘06 Xterra, It should be very similar to yours. Good luck and let us know how it goes!
https://www.youtube.com/watch?v=4DP7e7RO...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Robert Laney sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 1,499
