Ana içeriğe geç
Samsung tarafından üretilen bilgisayar monitörleri için onarım rehberleri ve destek.
Samsung SyncMaster doesn't connect with PC
Hi,
I got this Samsung SyncMaster P2370 from work, because they say it is damaged. The monitor starts perfectly and background lighting works, but the PC doesn’t react if I connect the monitor! The monitor shows an input-box icon and turns off after a while.
It has a DVI input and I use a HDMI-DVI-adapter and a HDMI-cable.
Anybody knows what’s going on or which parts I should check?
Thanks in advance!
Resim
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @muellerbua
Suggest you to take out the board with no 6 on it
inspect this board for any cold solder joint, especially on the DVI connector behind.
open the shield below and inspect the board if there is any abnormalities, e.g. burnt component, etc.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thank you! I will check it out!
tarafından
TY. Same here.
tarafından
Yorum Ekle
Just for the community: The display was completely fine! I just needed a VGA-DVI Adapter.
So apparently a HDMI-DVI-Adapter doesn’t work here
Puan 0
1 Yorum:
I have always used a HDMI-DVI-Adapter with no problem! As the above thread reads, the DVI connector can have a cold solder break from the pressure on the board from the weight of the attached cable.
Now does anyone know if it is safe to reflow that board in the oven?
tarafından
Yorum Ekle
Yanıtını ekle
Chris Müller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 920
