Hi @emilysmith ,
Try taking a picture (I realize that you cannot “see” what you are taking) and then download it to a computer.
If the picture on the computer is OK then most likely you have a motherboard problem in the camera that is not allowing the image being “seen” by the camera’s CMOS image sensor to be transferred to the camera’s display screen, which you say is still working. (can you view the menu screens OK?)
If the picture on the computer is not OK (perhaps just a black image) then most likely you have a CMOS image sensor problem or a motherboard problem or both.
Replacement CMOS image sensors are not cheap. (Although if this is the problem you may find one cheaper ;-)
Hi @emilysmith ,
Having now seen, after your update, that the “white screen” you mentioned is actually an error message perhaps the card slot is the problem by not detecting the presence of a card (have you tried a different one?) and not what I suggested above
If it is not detecting the memory card, perhaps that is why you cannot see an image. No point showing you a new image if you cannot "save" it to anywhere.
This is just a guess on my part and may be totally wrong
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
5 Yorum
Hi @emilysmith , have you fixed your problem? If so then how much does it cost? I also have the same problem
Al Jadid tarafından
Hello, please have you fixed the problem? I have the same issue.
Bulus Emmanuel tarafından
I am about to tear down a 70D with this "Image Snow" issue and will report back with some more detail once I'm in and diagnosed the problem.
Gavin tarafından
Everything I take a picture it is just a white screen
anabel sosa tarafından
I am also facing the same problem videos and picture are white. Showing Err70
SANTOSH THAKARE tarafından
