Mixing Paddle won't turn
Mixing Paddle does not turn whether in machine or out. Motor and pedestal for paddle work without pan but will not work in pan.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I had a similar problem, you need to perform the steps to replace the shaft seal then clean and lubricate the shaft. It may take a lot of force to remove the shaft. I used a dead blow rubber hammer and a drift to drive mine out. You need to be careful not to damage the shaft or bearing in the bread pan while driving the shaft out. As far as lube I used 3 in one oil but I’ll probably re-lube with silicone plumbers grease.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 1,519
