My tablet makes a wierd buzzing noise
Hi,I just recently came across my old tablet that was in the Boxes while we were moving to our new home.When I powered it on though,it kept on making some sort of wierd noise whenever I had it plugged in,or doing something on the tablet.I tried Factory Resetting the entire thing,yet it strangely did not work.My volume was off.And when I turned the display off,I felt some major heat coming off near the camera.
Keep in mind that it is still charging while I am currently using the tablet.I am using my iPad Mini for writing this question.
Update (10/05/2018)
I had it plugged into my power strip,here’s a pic of it
I have two of that power strip,it’s silver rated I think,but I had it plugged into the USB 3.0 ports at the end to charge.It was coming through both the strip,tablet & charger.But I have it plugged into my PC,and it’s not making any noise.
Update (10/06/2018)
Had to repost Primary strip
Update (10/05/2018)
This I saw the one that I am going to be using,as I use it the most during the day,the one that I shown you earlier was in the evening.It tries to basically tilt off what little room it has,so that’s why I have to put my finger’s on it.The cords lead to the following from left to right:
-Black Cable leads to Xbox One S
-Light Grey Cable leads to Wii U Gamepad charger
-Black Cable leads to Smart TV
-Light Grey Cable leads to Wii U Main Power
Bu iyi bir soru mu?
2 Yorum
Hi @indianarox ,
Is the noise coming from the charger?
Can you plug the tablet into a computer using the charger cable and check if it makes the same noise?
jayeff tarafından
I'm listening to music on mine and it keeps making a weird buzz sound and it's not charged up to anything and when I'm not using it, it still makes a buzz sound.
Jiselle Hurn tarafından
