How to replace the lcd sreen the akaso ek7000 pro
How do I replace the lcd screen on the Akaso EK7000 Pro?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
here is a link to someone attempting to open this camera https://www.youtube.com/watch?v=uvUApkjt...
at a rough guess the front screen is glued to the outer rear case and you will need to apply heat to remove it to access the flex cable on the motherboard. Having done a google of “replacement lcd”… I found zero… I’d say it’s probably cheaper to buy a replacement camera .
Bu yanıt yardımcı oldu mu?
You were right, but I had to take the camera completely apart and push the screen out from the inside. Only the bezel around the LCD was glued. Once loosened it came off easlily.
Thank you very much.
you're welcome. good luck
i dropped mine and the front screen fell off and I was in a rush because I needed to be somewhere and i just quickly snapped it back on although I snapped it on upside down with some dust on the inside. Why am I so stupid and how can I get into it again without a risk of breaking it or heat?
I believe this is a clone of the Eken H9
Here's a link to a teardown of the H9
I've watched the other linked YouTube video, and they are almost identical.
The screen is removed from the other side,
teardown of Eken H9
The bad news is - if it's like the Eken H9
The screen is firmware specific (matched)
ONLY the specific part numbered screen will
Also resolutions are fake
4k video (1080 real)
Anything above 4mp
does anyone know how to take an lcd screen off on an og akaso ek7000
Pretty sure it's similar to the Eken H9R
teardown of Eken H9 (1)
Less lifting of the screen, and more outward pressure on the case, so lever out and then lift
Just be aware too … the drivers for the screen are part of the firmware, so you can't use just any LCD screen (if you are replacing a broke screen)
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,007
