Ana içeriğe geç
Works only with Power Adaptor attached though Battery is 100% .
MacBook Pro late 2007 will operate only with the power adaptor attached. The MacBook charges the Battery and shows 100% Charged as confirmed by the green lights on the battery. Removal of the adaptor at any time shuts down the computer completely.
Is there a fix for this comdition?
Bu iyi bir soru mu?
Puan -1
1 Yorum
Apple MacBook Pro "Core 2 Duo" 2.2 15" (SR) Specs
Identifiers: Mid/Late 2007, 2.4/2.2GHz* - MA895LL - MacBookPro3,1 - A1226 - 2136
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Well this is a puzzling question. Please download and run Coconut battery and give us the results. Here's the application: http://www.coconut-flavour.com/coconutba...
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Coconut Battery reports Current charge: 4744 mAh
Maximum chare: 4927 mAh 96% as per battery monitor
Battery Capacity: Current Capacity 4927 mAh Design capacity: 5500mAh 89%
Details:
Mac model: MacBookPro 3.1
Age of your Mac 43 months
Battery Load cycles: 148
Battery temperature: 29.8 C
Battery Power Usage: 0.0 Watt
Is this what you (mayer) expected?
tarafından
I'm not ignoring your response, I just don't have an answer. Would you give us the last three figures of your serial number so we know exactly which machine you have. My answer would be different if this was not the unibody model.
tarafından
Last 3 numbers are X91.
tarafından
I think your best bet would be to replace the battery connector. You seem to be getting power to it but not from it. Here's the part: [bağlı ürün eksik veya kapalı: IF185-045]
tarafından
Yorum Ekle
Yanıtını ekle
Earl Stokes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 594
