Ana içeriğe geç
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Soru Tümünü görüntüle
Ds Lite Won't Read Games
I recently purchased a broken ds lite off of ebay to attempt repairing it as a little project. It won't read ds or gameboy games, so I assumed it just had some damaged pins. I opened up the ds and to my surprise, all the pins appeared to perfectly intact. I even put gentle pressure on each one and they all appeared well-attached to the motherboard. I then theorized that the pins could possibly be dirty, so after cleaning them off with some q-tips and rubbing alcohol, I assembled the ds and tested it. (Spoiler alert: that still didn't fix my problem, and all that my endeavors produced was a really clean ds lite lmao)
The two slots might need to be replaced, but it seemed like too much of a coincidence that both parts would be faulty.
I'm not sure what else could be the problem, if anyone has any ideas I'm all ears. Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum
A couple of questions, first of all, does the DS power on? Like power on but not reading games or does not power entirely
tarafından
@luckytechguys The ds powers on perfectly fine, I just can't get any of my games to work. However, according to the listing on ebay, it does have issues holding its charge.
tarafından
the top card slot wont read the ds card im putting in
tarafından
Mine terns on but won't read games
tarafından
Mine won't read the bottom one
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
From what you are saying, it is most likely that the card reader is fried from heavy use by the previous owner(s). You generally cannot fix it separately. The best option would be to buy a new motherboard off ebay. They typically cost from 10-30 dollars used. When you are looking, look at the pictures of the listings with the left Styrophome cover is not damaged. This is the piece that will detect a card has been inserted. If you don’t think getting a new motherboard is worth it, look at your old one and see if any wires are frayed on the left hand side. Good Luck and tell me how it goes!!!
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
if you are keen you can desolder the card reader and put a new one in....
tarafından
Yorum Ekle
Hey I thought this might help if it's not too late but I just purchased a ds lite from gamestop today and thought it a bad one not wanting to read games, in a non attempting way I had the games already inserted in the system while it was off and powered it on and boom the games finally were able to read (both ds and gameboy game) hope this
Puan 1
2 Yorum:
That's crazy, but I had this exact problem. Your answer was SOOO helpful. I spent 10 minutes cleaning my card reader, but still nothing. I was about to get entirely new parts, but I'm good now. Thanks!
tarafından
Any advice for me? Ive tried what said multiple times but my DS lite doesnt want to work. It worked perfectly fine before, then just stopped working all of a sudden. Ive cleaning it a little but it doesnt seem to help. Any advice?
tarafından
Yorum Ekle
Yanıtını ekle
Buckets G. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 30
Son 30 gün: 122
Her zaman: 14,398
