Ana içeriğe geç
Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
Frigidaire side by side Freezer and Fridge not cooling
My Frigidaire Freezer (high end 12 years old) isn’t cooling. Fridge is 45 (should be 38), Freezer is 41 (should be waay cooler than 32) measured by thermocouple on my multi-meter. The freezer fan is coming on. The condenser coil fan is coming on when needed. The compressor comes on, however it only stays on for a few seconds, then shuts off. It won’t keep going…
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There are lots of reasons for it not to cool but I think the first thing to check in your case is the (drum roll):
Start Relay
The start relay works in conjunction with the start winding to start the compressor. If the start relay is defective, the compressor may sometimes fail to run or may not run at all. As a result, the refrigerator will not be cold enough. To determine if the start relay is defective, use a multimeter to test it for continuity between the run and start terminal sockets. If the start relay does not have continuity between the run and start terminal sockets, replace it. In addition, if the start relay has a burnt odor, replace it.
It’s a cheap part if that doesn’t do it we can go into the multiple other possibilities.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
First thing you do is pull out your refrigerator and clean all the dirt out from behind it.
Then you take the back off the rear lower part of the fridge and clean all the dirt out around the coils.
And vacuum all the dirt as you carefully brush the coils..
You should do this this about every two years, or more if you have pets.,
IF YOU DO THIS your refrigerator will last 20 to 30 YEARS .
I have only bought 3 refrigerators in 60 years !
Puan 0
Yorum Ekle
How To Fix A Refrigerator and Freezer That's Too Warm
Puan 0
Yorum Ekle
Yanıtını ekle
zupatun sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 427
