Ana içeriğe geç
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Soru Tümünü görüntüle
What adhesive or glue can I use to stick the LCD screen to its base?
Hi,
When replacing the power button of my LG G5 the LCD screen got loose from its base and now it has a 2 to 3 mm gap on the left side. What type of tape, or glue, or adhesive can I use to stick it back? Is the iFix film, item code: IF303-087-1, intended for that? If yes, do I have to remove the entire LCD screen, put the film bellow, and then stick it to its base?
As only one corner of the LCD screen has a gap, I am inclined to use tape of liquid glue to deal with that corner only and not to have to remove the entire thing.
Thanks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
I took a risk and used “Superglue” from Locktite, around the inside edges, being careful that the glue does not go past 2 to 3 mms from the edges, allowed it to cure for 24 hours (glue instructions), and it worked! The LCD glass no longer has any opening gap and it looks brand new.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Fernando sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 2,500
