Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Can't Set Time & Date Automatically
Hi,
I can’t seem to configure the Time & Date on my iPhone 5C. My SIM is working fine and I get full signal, although when I choose to set time automatically it just hangs on setting the Time Zone. I just get the loading animation next to Time Zone and it never seems to load.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Donald,
It may be that it’s having trouble with location services. You can try to toggle some settings off and on to see if it will clear it. Also check if location services is even turned on.
Toggle:
Settings>General>Date & Time>Set Automatically (off/on)
Check if location services is on:
Settings>Privacy>Location Services (off/on)
Check if time zone has access to location services:
Settings>Privacy>Location Services>System Services>Setting Time zone option
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Hi Arthur, Thanks for the suggestion. Unfortunately I have already tried all of these and non of them seem to work. I have also tried a Network Reset and a Full Factory Reset with no luck.
tarafından
I'm sorry to hear that! I wonder if at this point it's a hardware issue. We'll see if anyone else chimes in.
tarafından
Hi Donald. A bit late but did did u manage to fix your issue? I'm having the same problem.
tarafından
@rishkadavids It's a relatively common hardware issue on 5Cs. Impacts on the iPhone creates micro-fractures at the WiFi IC. It can be fixed, although not absolutely reliably, by a reflow or better a reball of the IC. Given present value of a 5C such a repair would cost more than a working 5C iPhone.
tarafından
How set time and date iPhone 5
tarafından
Yorum Ekle
Yanıtını ekle
Donald sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 35
Her zaman: 1,432
