Ana içeriğe geç
Fireplaces that use gas instead of wood to make fire.
1 Soru Tümünü görüntüle
Soru Kapandı
Why is my heatilator Rave 4013 gas fireplace go out after lighting?
I have a Heatilator Rave 4013 that keeps going out. This unit has an electronic ignition igniter, so it doesn’t have a pilot that is always lit. When I flip the switch it turns on and stays on for a few minutes. The flame will suddenly start to flicker and go out, as it is doing this you can hear the igniter engaging. What could be causing this?
Thanks for your help.
Aaron
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Gas Fireplaces are really outside our skills set.
I recommend you talk with your local dealer or check out Heatilators’ web site directly here: Heatilator- Troubleshooting & FAQs
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The safety device has activated. The oxygen depletion thermocouple could need replacing.
Also is there a supply of gas to the fire ?
Or maybe the gas valve itself is blocked.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 272
