Ana içeriğe geç
Guides and support for various television (TV) brands and styles.
9048 Soru Tümünü görüntüle
Matching a replacement powerboard.
Hi,
I have a Panasonic TH-P50G10A Plasma which was struck by lightning and fried the power board. I would like to replace this myself with a cheap used powerboard out of a broken tv, and struggling to find the exact part. Is it possible to use a slightly different part? I have found a part with the same part # except for the last letter.
ETX2MM747MF K (in tv)
ETX2MM747MF E (found replacement)
My question is, can I use this part? Or how can I find what parts will work to expand my search?
Cheers.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Usually the difference would indicate a different revision of the board - something as simple as a new part vendor or minor component change.
If the seller states it is compatible with your model TV then I suggest it will work. Just make sure that all plugs/sockets/wires etc match up properly when you install it.
HIH
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Sounds like workable advice to me. +
tarafından
Yorum Ekle
Yanıtını ekle
Peter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,397
