Battery charges extremly long.
Hello folks,
my MacBook Pro Battery takes a long time to charge plus when my macbok is not connected to the charger it sometimes turns suddenly off, like it loses connection to the battery.
The Battery is already replaced and I did plenty of SMC and PRRAM resets.
About three months ago the logic board got replaced because of another issue…
I tried all tests with the ASD but the macbook passes everything apart from the internal 2D acceleration test.
I have a multimeter here, so I can measure the most important things, if I‘d know which…
Thanks a million in advance,
Phil
Bu iyi bir soru mu?
3 Yorum
Did Apple do the board replacement? Was it warranty work?
mayer tarafından
Have you checked with CoconutBattery? Or also by option clicking the battery menubar item?
rab777hp tarafından
Yes it was a warranty replacement by apple. Unfortunately they don‘t want to repair it now, because it has some dents here and there, which is a bit weird because it had the same when I did the first repair.
Coconut Battery says the same and option clicking in the menubar says that the battery is fine.
Senior Flipsos tarafından
