Ana içeriğe geç
Dell Inspiron 15-5565, Dell tarafından üretilen 15 inçlik bir dizüstü bilgisayardır.
Laptop doesn't power on
Opened my laptop to clean out the fan. After I reassembled it, it worked fine, but I realized it was not charging. I took it apart again and realized that i forgot to re connect the adapter port to the mother board. I reconnected it and reassembled and now the laptop will not power on. Nothing happens when I press the power button.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Hi Andrew, when you connect the power adapter to your computer, do you see an indicator that there is power?
try reseating the LVDS cable to the power button to the main board.
tarafından Paylaş
GPU and CPU are integrated on the board. Is it possible I shorted a power rail the second time I took it apart?
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
You can take it apart again and see if you find anything along the way. Check the seating of the video card, CPU [ and the cam on the CPU ] and memory. It may work when you put it together, if so you have had a win. There is also a chance you have done nothing wrong, it may have been ready to fail next power on.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Andrew Young sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 420
