Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
4090 Soru Tümünü görüntüle
Unknown part (wire) in iPhone 5s
I was replacing back housing on my iphone 5s and I am curious what is this wire used for?
Thanks in advance
Vito
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Vito, this wire is for the main cellular antenna. Without this cable, you phone will have 0-1 bars signal with your cellphone network. This part is unrelated to wifi, Bluetooth, or GPS.
Have you broken the cable? If so, do not worry as a new cable will come preinstalled on any replacement charger port. The charger port flex PCB is only a $10 part. However if you have damaged the round plug on the motherboard where this cable attached, you will need to bring the phone to a local repair shop. This would require a skilled to solder on a new antenna port.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
+1...that's a better answer than mine :>)
tarafından
Thanks. And no.... i haven't broken it I was just curious.
tarafından
Yorum Ekle
Yanıtını ekle
Vito Tivadar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 30
