Ana içeriğe geç
Toyota Matrix temel alınarak üretilen 2009-2010 model Vibe; ekonomik bir baz donanım, orta seviye bir AWD (dört tekerlekten çekiş) donanım ve daha fazla güce ve manuel şanzımana sahip sportif bir GT versiyonu ile sunulmuştu.
Passenger side window won't go up
Window won't go up using driver or passenger switch. All other windows will go up except passenger front side window
Update (12/23/2018)
Once thing I forgot to mention is that the passenger side will go down but not back up and only will go down by pressing the button on the passenger side but not on driver side main window panel @jimfixer @captainsnowball
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
on page 225 of the manual (https://my.gm.com/content/dam/gmownercen...) check fuses 3, 4, 5, and 27.
Resim
If any of those 4 fuses looks like the bad fuse shown in the image, then theres the issue. you will need to replace that fuse with one of the same amperage (same number written on the fuse)
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Well done @captainsnowball Ive never seen a vehicle that has 4 fuses for power windows before , most cars have 1 fuse fore both windows and power door locks. I would have looked right past the fuse issue since the other windows worked. That being said @missycanty Listen closely to the window when you try to run it do you hear a hum or any noise at all coming from the window . If so it could be a faulty window regulator . If no noise is heard and the fuse is not blown it could be a faulty window motor or bad wiring in the door. Hope this helps
This video gives an idea how to replace the regulator
https://www.youtube.com/watch?v=R-rWs0vA...
Puan 2
Yorum Ekle
I’m having this same problem. Can’t find the fuse #27. I’m driving 2009 GT
Puan 0
1 Yorum:
Any help would be great! The cover is not the same as the manual. And the actual fuse block doesn’t have #26 and #27.
tarafından
Yorum Ekle
Yanıtını ekle
Missycanty sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 5,762
