Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
222 Soru Tümünü görüntüle
Can I create a bootable macOS USB drive in Windows or Linux?
Hi, I would like to be able to create a bootable macOS USB flash drive, but it seems that the only official way is to use a Mac. I don’t have a Mac, so is there a way to create a bootable USB macOS drive in Windows or Linux that doesn’t involve hacked ISOs and whatnot?
Please note: I had to select a machine for this question, so I just selected a 2012 Mac Mini.
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Most Mac’s offer internet recovery which allows you to install the MacOS from the net How to Re-Install OS X with Internet Recovery on a Mac
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It is possible you can get a app for windows called Trans Mac keep in mind that you need the OS X file also you need a 8gb drive or more and it should do all the work. You just have to select format disk for mac then once your done with that select restore disk image then go find the OS X image on your pc then it should do all the work for you.
Puan 0
Yorum Ekle
Ok, I’ve found the answer. If you have a Install macOS Mojave.app file, which I got from somebody else’s supported machine, you can flash the /Contents/SharedSupport/BaseSystem.dmg to a USB drive with a tool like Etcher. The only catch is that this is a recovery partition image, so you the bootable USB will download a copy of macOS from Apple’s servers, but at least it offers the option for machines that don’t support internet recovery, because I don’t own a Mac.
Puan 0
Yorumlar:
Hi Rupertus,
did you check this ?
https://hackintoshpro.com/bootable-usb-m...
Rob
tarafından
If you have a 2012 Mac mini you don't need to go to such lengths it has internet recovery which will allow you to create a bootable drive (internal or external).
Reference: How to Start up Your Mac in Internet Recovery Mode
Then once you have a bootable drive you can then download the OS installer from the Apps Store. You can even create a OS installer to setup other systems How to create a bootable macOS Sierra installer drive
tarafından
Yorum Ekle
Yanıtını ekle
Rupertus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 35
Son 30 gün: 233
Her zaman: 4,158
