Ana içeriğe geç
Sony CFD-S05 CD Radio Cassette Player was released in 2010, and has the CD-R/RW playback function.
25 Soru Tümünü görüntüle
cassette will not play when powered up
I have power for the radio and cd but when I switch to tape it will not run , just the display indicates “TAPE”. The belt drive is not damaged and it seems that the motor will not run . Is there a test I can do on the motor ?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you can, touch the probes of a multimeter on a voltage range on the connections to the motor, and see if you can see some volts when you press Play.
Are you sure the belts are ok and the motor isn’t turning? If it’s some years old the belts may well have perished and gone slack. It would be somewhat unusual for the motor to have failed.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
David and Lori Hurley sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 102
