Ana içeriğe geç
I´ve a vertical white line in the screen that appear after my lapt hit
Hi Guys
My laptop was running out of thermal past and because I have it always on at home but I don´t use it very often, I didn´t realize about it, I only saw it one day that it just turned off running super hot.
I´ve open it, I put thermal past in the CPU and it works very well again, except for one very samall detail, a white small line appear in the screen and I´m not sure how to solve it, because I´m afraid that the display is fine, but eigther a connector or the video card can be damaged due to the high temperature.
I appreciate any help.
Thanks,
Mauro.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @mruizdia ,
Connect an external monitor to the laptop and check if its' display is OK.
(even a TV can be an external monitor if you have the correct cable and the TV has the appropriate inputs)
If it is OK then the GPU is OK and the problem is either with the LVDS cable or the LCD panel.
You did disconnect the battery after you opened up the laptop and before you worked on the repair, didn't you?
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
The video chip may have a bad solder connection. Take a fine magnifying glass to it, and check for blackened or corroded contacts. If there are any, clean it off, use flux and a nice hot soldering iron, and apply a little solder to it. The LCD connector may also be faulty. Check on that too.
Puan 1
Yorum Ekle
Yanıtını ekle
Mauro Ruiz Diaz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,050
