Ana içeriğe geç
Simple to use 35 mm manual focus SLR camera. Model number X-370.
25 Soru Tümünü görüntüle
How do I unlock my camera?
The batteries in my camera seemed dead and when I changed them the shutter was still inoperative.I have been told that because the batteries went dead the camera is "locked up". How do I unlock it ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Seems this is a somewhat common issue
May be due to a failed capacitor.
Refer THIS post but the manual link is DEAD - trying to locate a good one for you
HIH
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
THIS link is to a online version
tarafından
Nice research. +
tarafından
+ great link
tarafından
Richdave...Wicked research and thank you very much. Confident I can fix it myself now.If you ever need any automotive advice I can help with that.Thanks again !!
tarafından
NP :-) Happy to help
tarafından
Yorum Ekle
Check to make sure the 'bars' on the shutter are all the way to the left and invisible. If you can see them, try pushing gently with a fingernail until they slide all the way left. This may unlock the camera.
Check the release capacitor on the bottom. If you see any green on the leads it is bad - heat one of the leads with a soldering iron - if you smell 'fish' then it is bad. If leads have leaked onto small circuit board, try cleaning with isopropoyl alcohol. If leakage is too bad, board will have to be replaced. Part is of course no longer available, as Minolta is out of business.
Puan 0
Yorum Ekle
Yanıtını ekle
leafsveteran sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 2,626
