Why is battery over charging but not all the time
95 jeep battery is usally12, it has been up to 14 but never the same
Bu iyi bir soru mu?
Bu iyi bir soru mu?
When your engine is running the battery voltage should sit around 14 volts if your alternator is working correctly. When the engine is not running your battery voltage will drop back down to roughly 12.6 volts. What you described sounds like normal operation unless your voltage is ever out of that 12-14V range. Hope this put your mind at ease!
Bu yanıt yardımcı oldu mu?
Thank you for your quick response, Travis. I appreciate it & you
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 87
