Ana içeriğe geç
2012 yılında piyasaya sürülen Asus N76VZ, 1600x900 piksel veya 1920x1080 piksel ekran çözünürlüğüne sahip 17 inçlik bir dizüstü bilgisayardır. İçerisinde 3. nesil Intel Core i7 işlemci ve bir Nvidia grafik kartı bulunur.
Why can't remove battery
Hello
I am trying to remove battery on Notebook Asus N76V, but I think it have problem with the slider lock because he is on the wrong position and now it is very hard to remove it, I tried a little force to remove it but I wasn’t able to do it… I searched many solution but I didn’t found the solution.
Edit: it is Asus N76VJ but I think it’s the same way to remove battery.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It’s likely that the slider to unlock the battery is broken. First try sliding it to the unlocked position and force the battery out. There isn’t much you can do other than replacing the bottom case. I’ve found though that a lot of times if I force it out, it will come out with little damage.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
with flat head screwdriver,
start to lift battery pack from back ( furthest away from battery open slider )
start to lever from right or left ,,, lever from either corner
This worked for me and i did no damage to mechanism
operate lever and apply some silicon spray
Puan 1
1 Yorum:
This was actually helpful!
I used a plastic pick and started wiggling and sliding.
I spent more than 30 minutes trying before seeing this tip, and I was so happy that I didn't break anything lol
Thanks
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Mickael Gomes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 29
Her zaman: 1,445
