Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
I'm scared to turn on my iPhone
I dropped my phone in my bathtub earlier and I got scared. I opened it up and used the cool setting on my hairdryer to dry the phone and its hardware and everything. I put it all back together and Now the screen wont go all the way in and I’m scared That i’ve accidentally punctured my battery. Its all in place but I’m scared to turn my phone on. Should I turn it on or not? what would you recommend?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hello,
I am understand that your feeling so don’t be panic just clean your phone internally means If your handset has a resemble battery, similarly your phone has some kind of port cover or even a removal back panel, open it up to let your handset air out,
Don not dry your phone with a blow drier because the heat from the drier could damage your handset internally components permanently.
After the clean out your device cleaner (liquid) after that on the phone and check it. But you will be this work quickly,
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi Vidhi,
I can totally sympathize with you here - a punctured lithium ion battery is no joke but signs of swelling are pretty easy to spot
Seating the display bezel in the phone body does require a bit of extra force for it to click into place and for the display to be seated correctly.
Once you’ve given the battery another inspection, try turning the phone on. If the battery is expanding, you’ll be able to see the pressure marks plainly on the LCD. You need to turn the phone on to assess what other damage may have occurred and determine if you are able to repair it.
Puan 0
Yorum Ekle
Yanıtını ekle
Vidhi Patel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 56
