Ana içeriğe geç
Computers that generally don't include an integrated display, and are meant to be stationary.
1134 Soru Tümünü görüntüle
Can I take my hard drive from my old pc and put it in my new pc?
Hello,
I am upgrading to a better computer and I was wanting to know if I could take the hard drive from my old pc(hp) and put it in the new pc(dell). The problem is, the HP has an AMD cpu, whereas the dell has an intel cpu.
The hard drive itself is a decent one, it is a Western Digital blue 1TB WD10EZEX, fast little drive.
The only problems I could see happening are driver issues, but I have driver install/repair software that works well.
So my question is, will this work or not?
**Note, this will not be permanant, I only plan to run this setup untill I have enough money to buy a new HDD and SSD.**
Update 1/27/19
I just tried this today, and it did not work!!. The computer turned on and everything, but there was no display and it seems to have failed to detect the wifi module because it would not come online on teamviewer, so I wasnt able to go in and remotely fix the problem.
What do I do now?
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Dizüstü Bilgisayar Bataryaları
An easy fix for a big power boost.
Hemen Alışveriş Yapın
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You should have no problems as long as the old drive a an SATA rather than an IDE. In other words, if the connectors are the same you are OK.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
So there shouldn't be any issue with switching to an entirely different processor? Also, both pcs use sata connectors.
tarafından
I just posted an update, more or less it did not work at all.
tarafından
Programs like Acronis True Image have their universal mode which automatically updates drivers during first boot up on a "new" system.
I've successfully used it many times.
tarafından
Yorum Ekle
Yanıtını ekle
Connor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 55
