side by side samsung water dispenser will not stop shooting water
I have a Samsung rsg257aars side by side water dispenser will not stop dispensing. I heard that filter not sealing can cause this. I replaced the filter and it work fine for a few days then started again. I also tried a Samsung brand filter ($50 from Lowes) still no luck. I am thinking about replacing the filter housing next but I wanted to check here before shelling out another $70. It does the same thing without a filter.
More info. The ice dispenser works fine so that ruled out the microswitch. I even tested the microswitch separately with a meter. works perfect,
I look forward to hearing from some more experienced folks out there
Bu iyi bir soru mu?
5 Yorum
Any update? We have the same issue. Replaced the water filter and was ok for a week only. Repair man wants $500 for the water valve but says he isn't sure it will correct the problem.
mskrisham@hotmail.com tarafından
My ice and water dispenser will not stop. Water or ice goes constantly. I had to turn off the water to the fridge. I want to replace the water inlet valve (approximately $100 from parts store) but was informed part # DA62-04027C is no longer being made by Samsung! You can't get it. Any suggestions?
N Thomas tarafından
Mine just randomly starts shooting water sometimes even when I'm asleep. I also have a thick layer of ice under the refrigerator drawer. The only way I can stop the water is by turning the water supply off, unplugging it and letting it reset. I have no clue why there is ice under the freezer drawer. Help!! roger120275@yahoo.com if you have any ideas please email me.
Roger Kincaid tarafından
Did anyone ever find a fix?
gBesPirate tarafından
@mskrishama75951 any update for you? Or did you just throw the fridge away? Lol
