Ana içeriğe geç
Model A1213 / 8, 16, or 32 GB capacity
216 Soru Tümünü görüntüle
iPod A1213 When powered on shows only the “itunes” picture
when powered on the ipod A1213 shows itunes picture - should i reset ?
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
ugyen try to hold down the home and power buttons at the same time until it shuts down and reboots. This should take it out of recovery mode. the other thing you can try is to download iReb from here and see if you can kick it out of recovery mode. Good Luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Have you managed to successfully restore your iPod using iTunes? That screen usually shows up only if your iPod's firmware is damaged in some way or another.
A restore will usually get it working again, but if it still shows up even after a restore, your iPod may have another issue that may need higher up help.
Puan 0
Yorum Ekle
Yanıtını ekle
ugyen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 4,081
