A few tips to add to the previous helpful posts:
1) Use a flat thin (~1” x 5”) flexible plastic strip (cut from a plastic disposable food container) to jimmy the microwave door open.
2) Use a thin screwdriver or stiff metal wire (e.g., from a wire clothes hanger) to pop the trim screw covers (if you have them) from the other side so as to not scratch the pop-on covers.
3) Keep the microwave level when moving it, so the broken cam piece doesn't get lost under the microwave.
4) Use a Torx security T15 bit to open the case.
5) Use a minimum 1 inch #4-40 screw and nut. It will be easier if the screw is 1.25" or 1.5".
6) Put a tooth/serrated washer before the nut to prevent loosening. I did it the first time without the washer and the screw loosened, the post got wobbly, and the plastic lever popped out after 8 months. So I put a tooth washer in the second time.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
3
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
5 Yorum
Hi,
What is the model number of the microwave oven?
jayeff tarafından
Thanks Dave and Paul. This was exactly our problem. Called Sears Service and they wanted $362.00 to fix. And we would have to wait 3 weeks for parts. With your instructions is took us 3 hours and we used a bolt through it as suggested. Works great!
Judy Gerba tarafından
all sounds good , although Im having the problem of getting the door open.
Loretta Ronnenkamp tarafından
All the comments below sounded like they worked for the folks asking. However, I am 80 years old, could not possibly get the unit off the wall and have no idea of half the things they are saying. I just pry it open with a knife. 😂. Guess that’s the best I can do.
Judy tarafından
Have had my GE Profile microwave for 15 months and now door won't open. Sometimes it does, sometimes it doesn't. I think the problem with mine is the hinges aren't holding door in proper position. If I slightly lift the lower right corner of the closed door up, the door will pop open. Just now I put a piece of ¼" high cardboard under the hinge and the door easily opens. The cardboard sits under the silver hinge. Because it is an outside hinge on bottom left corner of microwave, the cardboard doesn't interfere with ability to close the door securely.
Zasu Zasu tarafından
