Most of the time users can easily use Kindle Paperwhite. We know the Kindle is a smart device, and it needs a fast network and powerful signals. When the signals or other issues occur, we can face Kindle Paperwhite won’t connect to Wi-Fi. It is also necessary to fix the issues quickly. The primary reason for this is the network. Sometimes we forget to turn off airplane mode. When we are using the lower version of the software, we can face these types of errors.
Users can quickly fix the error by using the best methods. It is also critical for us to read all instructions and follow them properly. After this users can quickly resolve the error of Kindle Paperwhite won’t connect to wi-fi.
There are several tricks we can use to increase the battery life of our Kindle devices. We increase our battery life when we turn on airplane mode, and we complete the book properly. After using them, we forget to turn off their airplane mode, so the Kindle cannot connect to Wi-Fi. You can go to the Quick Menu. We can see the plane icon here. Select airplane mode from the wireless settings menu.
Users can also restart their Kindle and fix the Kindle Paperwhite won’t connect to wifi. When we restart our Kindle device, it quickly fixes the error. The process of restarting is simple and easy. There is a power button on our Kindle device. Now press and hold the power button for a few seconds. After this restart process is complete. Here it is necessary to check whether the issue is solved or not.
There is an option for us to use the delete wifi password and again connect with them. Sometimes we change the password and forget to save it. When we attach it to our device, it shows the Kindle Paperwhite won’t connect to Wi-Fi. It is always vital for us to save the new password and attach it manually.
Users can also update the software on their Kindle Paperwhite. When we update the software, it automatically fixes the bugs and technical glitches in the device. There is a need to quickly update the software, so it works properly. It also fixes the Kindle Paperwhite won’t connect to wifi.
It is necessary to reset the Kindle if all the above methods fail to connect the Kindle to wifi. When we reset the Kindle, all the data stored on the device is deleted. To reset the Kindle device, it must be charged properly. Resetting the Kindle is simple. We can go to settings > device options > reset. After this Kindle quickly connects to wifi. Now the Kindle Paperwhite won’t connect to wifi is fixed. It is also necessary to use the above methods and fix the error quickly. Now users can skim their favorite e-books on Kindle.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
11 Yorum
I have the same problem with my Kindle. It can't find any Wi-Fi network. Even after resetting. I also noticed that the battery discharges very quickly when Wi-Fi is on. And I also noticed that in the device info, the MAC address of the Wi-Fi is unavailable.
Lionel PLAIS tarafından
Solution was to type in full network key for the WiFi. Since the router was not labelled in English I did not use the right code at first.
david.j.james88 tarafından
The solution above is not the answer, mine also shows no networks, and I cant get it to do anything 'manually'. I have updated to 4.1.4 and this is the same.
jonathan_obrien tarafından
Jonathan, please try a hard reset of your kindle. Check you have the latest firmware on your kindle. Then check that other devices can see/use the WiFi network you are trying to use. Also try a different (public) WiFi network. If these (simple) measures do not work, I can only suggest to try Amazon.
Tried all that!
6 tane daha yorum göster
