Can’t insert discs into optical drive (mechanical block)
Hi,
my xbox one s optical drive has an issue. I can not insert discs into it. It tries to push them inside but gets blocked.
I disassembled my xbox and removed the metal casing from the optical drive and I found that the center white plastic piece that’s meant to hold the disc once it’s in is actually blocking it from getting inside in the first place. If I remove it then the cd goes in, but of course then the drive is unusable.
I found that the disc hits the center of the plastic piece, which means that the plastic piece sits way too low.
Is this piece supposed to go up and down depending on use and mine is just stuck at this one position?
Is there a way to fix this?
Here are photos I took to demonstrate what blocks the cd and how it meets the blocking piece inside the drive. https://imgur.com/a/3VxrCVK
Thanks.
Bu iyi bir soru mu?
