Ana içeriğe geç
PS3 ile birlikte gelen kontrolörler için onarım ve destek. 2007 (yalnızca Japonya) ve 2008 (diğer ülkeler) Kasım aylarında piyasaya sürülen altı eksenli lityum pille çalışan kontrol cihazının (CECHZC2) onarımı oldukça basittir.
Can't get the vibrators out
So my remote had the entire left handle sheared off,
but it still works so im gonna try to fix the damage, but i cant seem to get the vibrators out as the guides appear to have different models (if that's even a thing idk) and so im kinda stick. Appeceriate help.if possible
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
First thing I usually check when I am experiencing difficulties with any repair is how the part looks to be secured. Check if it looks like there is adhesive or if there is small screws. Obviously both would prevent you from removing the vibrators. I will assume there are no screws because it should be obvious is there is. Again assuming it is adhesive the easiest way to soften/weaken the adhesive is using isopropyl alcohol. This should break down the glue enough to allow you to carefully pry the vibrators out. You can use a spudger if you have one, if not a small flat head screwdriver and make sure not to pry on any points that could break off (like in between the body and rotating weight) but rather somewhere like the main body (the larger, metal section) of the vibrator. Hope that helps!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
TaloNNn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 45
Her zaman: 392
