Ana içeriğe geç
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Soru Tümünü görüntüle
2011 iMac 27" EMC 2429 not powering up, can I rule out power supply?
Mid 2011 27” iMac A1312 EMC 2429
My iMac will not power on. When I hit the power button, I hear no chime and no fans. I have already tried unplugging it and holding the power button, then replugging it in. I have tried removing the RAM, dusting and putting it back in.
I removed the display and gave everything a good dusting. The far-left diagnostic LED is on and green. The other 3 LEDs will not indicate anything because I can’t turn on the computer.
I have tested the voltages on both the power supply and the logic board with a voltage meter from the back.
Power Supply Results:
  • Pin 1 - Ground
  • Pin 2 through 4 - No voltage
  • Pin 5 - 14.78 V
  • Pin 6 - No voltage
  • Pin 7 - 4.06 V
  • Pin 8 and 9 - No voltage
  • Pin 10 - 3.63 V
  • Pin 11, 12, 13, 14, 15 - approx. 13.5 V
  • Pin 16 - No voltage
Logic Board Results:
  • Pin 1 - Ground
  • Pin 2 through 5 - No voltage
  • Pin 6 - 4.2 V
  • Pin 8, 9, 10, 11 - 15.2 V
  • Pin 12 and 13 - No voltage
  • Pin 14 - 4.2 V
Is it safe to rule out the PSU as the problem here?
If it’s not the PSU, what should I check next? Could this be a problem with the power switch? Any suggestions would be greatly appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sadly your power supply has failed. Here’s the needed part iMac Intel 27" EMC 2309, 2374, 2390 or 2429 Power Supply. There is additional logic within it that offers the soft power switch function.
iMac Intel 27" EMC 2309, 2374, 2390 or 2429 Power Supply Görseli
Ürün
$139.99
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
Hi Dan. Thanks for responding. The power supply just arrived today and I installed it. Unfortunately this has not solved the problem. My mac still will not boot up. There is no sound of fans and no chime. Diagnostic LED still reads one light (far left). Do you have any suggestion of what to test next? Possibly the power switch itself? Thanks again for your advice.
tarafından
Quick update: I tried bridging the power button prongs with a piece of wire with no success. Please let me know if you have any other ideas to help isolate the problem! Thanks.
tarafından
Replace the power supply
tarafından
I did replace the power supply yesterday, but I was still unable to turn the computer on. Any other ideas?
tarafından
Sorry, I didn't read your first note only the update. Well thats not good ;-{ Only one thing left - Logic board. Before returning the power supply install the new board just in case you had a double hit where both got damaged.
tarafından
1 tane daha yorum göster
Yorum Ekle
I have same problem except moving fan in few seconds when i press the power button. Yesterday i replaced new PSU receving from ALIEXPRESS. The result was successful but today morning my it has same problem when i press the power button. I could not understand what happen on my imac during one night. I frustrated this result… If you have any successful results, Please inform me
Puan 0
Yorum Ekle
Yanıtını ekle
A Longmire sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 838
