Touchscreen and buttons not responding EXCEPT the 'new 3DS' buttons
So, my New 3DS developed this funny thing last week. After a few minutes of being turned on, all input would freeze with the exception of the ‘new 3DS’ buttons. For example, I can still scroll through the home menu using the nub (C-stick?) and the two small bumper buttons. However, I cannot select anything as the A, B, X, Y, touchscreen, D-pad, circle pad and the large bumpers are all unresponsive.
Since then the problem has started to occur earlier and at present it manifests right from when I start the console.
While it was still working, I’ve done a factory reset and updated to the latest software, none of which helped.
I’ve opened the console up but couldn’t discover any physical cause.
Any ideas?
Bu iyi bir soru mu?
My son's New 3DS is having the exact same issues. As soon as the 3DS is powered on the touchscreen and buttons, with the exception of the New 3DS buttons, all become unresponsive.
I tore the whole thing apart, checked everything, saw zero signs of damage and put it all back together again without a single issue. I checked online and could not find any helpful information on the matter. You are literally the only person I could find that is or was having the exact same problem.
I know this question was asked years ago but I'm still hoping that maybe you will see my response. Did you ever find a resolution to our dilemma? Is there any advice you could give me?
Heisenburrrg tarafından
"You are literally the only person I could find that is or was having the exact same problem."
Isn't it amazing. As it happens I have had zero response in all these years and the 3DS has been lying around all that time. Cool that we got a solution from @nothing666 and will try that, let you know if it works.
Mathijs Booden tarafından
dear @mboodenak,
Would you mind if you could make this a question and further describe your issue as i could help you more there.
Nick P tarafından
Dear @np_f1_2021 ,
I'm not sure I get it. My question is already a question, right?
Oh I just realised, whoops. My bad
Nick P tarafından
1 tane daha yorum göster
