ASUS ZN240ICGK-RA030T SSD+HDD? Replace or ADD
Model ASUS Zen AIO ZN240ICGK-Ra030t. Hello. Can I install a second SSD on this model? or just a replacement instead of HDD?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
No, there is only one SATA connector on the main board and there is not enough space to install a second disk. However, you can easily replace the original installed SSHD with a 2.5-inch SATA SSD drive.
Check out this guide to better understand how the components are allocated inside the case:
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 325
