Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3531 Soru Tümünü görüntüle
iPhone Battery Replacement: Detected by PC but black screen
Recently Swapped out the battery on my Iphone 5s.
It was confirmed working when i tested it before re-assembling the phone. Whilst putting the LCD back in the frame, i found a problem with the top of the LCD not sticking to the frame, only to find the glue at the top is not sticky at all.
I removed the LCD again to try and resolve it and now the screen does not display anything. Holding Power and home button for 15 seconds, detects the phone on my PC but this is the only way i can get it to connect to the PC.
Any Help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
No vibrational feedback from mute switch.
Screen came off first before unplugging the battery. Seems silly now i’m thinking about it, but i was following a guide step by step at the time.
Have tried disconnecting the battery holding the power button then reconnecting but still nothing.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Have you tried toggling the mute switch on and off to see if the phone is alive? (this helps to see if it’s just the screen that is malfunctioning) Also before you removed the LCD ESD shield (top right metal plate with 4 screws), did you unplug the battery before anything else?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
mattling9 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 28
